1 Востаннє редагувалося rodeoneerer (09-01-2025 10:54)
Тема: How to Complete the True Grit Task in Gray Zone Warfare
In Gray Zone Warfare, the True Grit task can be a tricky one, especially when it comes to finding the revolver. If you’re struggling to figure out where to go or what to do, this guide will walk you through the steps to complete the task quickly and efficiently.
Task Overview:
The True Grit task is assigned by Handshake after completing Gunny’s task in Hunter’s Paradise. Once you finish Gunny’s quest and report back, you’ll be given the True Grit task, which involves finding an antique revolver located near the shooting range. However, the quest description can be misleading, making it easy to get stuck.
Step-by-Step Guide:
    Find the Motel:
        While the task description says the revolver is near the shooting range, it’s actually located in the Hunter’s Paradise Motel, which is south of the range. Look for the motel at map square 160, 167, as this is where you’ll find Room 102, where the revolver is stored.
    Locate the Key:
        To access Room 102, you’ll need to find the Hunter’s Paradise Motel Room 102 key. This key can be obtained by looting the bodies of AI enemies around the area. Unfortunately, the key doesn’t spawn frequently, so you may have to kill several AI enemies before you get lucky and find it.
    Unlock the Room:
        After obtaining the key, head to the motel and use it to unlock Room 102. Inside, you’ll find the antique revolver inside a red case next to the bed.
    Secure the Revolver:
        To avoid losing the revolver if you die on the way back, place it in your secure container. This ensures that you don’t have to repeat the search if you encounter danger on your way to your base.
    Return to Handshake:
        Once you’ve secured the revolver, return it to Handshake at your base to complete the task. You’ll receive your rewards and the task will be marked as finished.
With this guide, you’ll have no trouble completing the True Grit task in Gray Zone Warfare. Good luck!
Welcome to Buy Gray Zone Warfare Dollars from professional and trustworthy game currency store - z2u.com with fast, safe worldwide delivery, full stock meet your demand all time! we promise all cheap Gray Zone Warfare Dollars for sale here are 100% safe to use in-game!
